NHStuff
Jun 06, 2020Aspirant
Restrict Firewall exception to a specific incoming IP
I'm looking to open up Port 22 (SSH) for incoming traffic from a specific IP only (not open to the world). Can't seem to find the proper firewall/router configuration for this. Suggestions?
- Jun 06, 2020
Not possible on stock firmware. Well, it's doable, but you'll need to mess with iptable rules
NHStuff
Can you recommend an alternative model (or Brand) that's more suitable for this need?
I have this requirement and will be looking to replace the R7000 with something capable of handling this traffic restriction.
Thanks!
microchip8
Jun 06, 2020Master
AFAIK, no other brand supports that. Also, we can't recommend other brands here as there were people banned by doing so
- NHStuffJun 06, 2020Aspirant
Yeah... that's just not ok. I see several posts from individuals needing this same functionality to keep their SIP/VOIP systems viable - past time for Netgear to step up.
Returning this to Amazon I guess. I know I can do this in Cisco IOS, but was hoping for an easier path.
Thanks for the information.
