euyter
Mar 30, 2022Guide
Returning to original firmware after ExpressVPN R6700v3 — Nighthawk AC1750 -
I have been running ExpressVPN successfully on my Nighthawk AC1750 - R6700v3 for the past year. I will be switching to BitDefender and would like to have the original firmware installed back on the N...
- Mar 30, 2022
After getting back in a text chat with support for another 1.5hrs the solution took about 5min.
I hate how it took that long but here it is.
They suggested I try expressvpnrouter.com:8080expressvpnrouter.com is how you access the router dashboard/interface
the :8080 didn't work but I got the idea to try the routers ip address and :8080
This worked!
For example 192.168.123.1:8080 in my browser
This took me to a different interface that was dd-wrt. I was easily able to login as admin with my same admin and pass and then uploaded the most recent firmware.
Initially this didn't work.
I uploaded the file and expressvpnrouter.com was no longer accessible, nothing was couldn't do anything. When I checked what the ip address of the router was it was the same.
So I decided to reset it, bingo once it loaded up I had netgear firmware/interface installed.
Wish they would have told me about :8080 from the beginning, would have saved at least 2hrs of my time.
Hope this saves someone elses the time.
Mar 30, 2022Guru - Experienced User
I'd post in the expressvpn's forum for help.
Its their 3rd party firmware that caused this issue.
I'd double check the firmware version you're using to compare with the label on the device.
euyter
Mar 30, 2022Guide
As far as I'm aware they don't have a community forum like this and I have already talked with support there and they don't have an answer but did tell me this is a known issue with no actual solution after they ran me through everything I have already tried.
- euyterMar 30, 2022Guide
This worked!
