Laurent78
Nov 29, 2021Aspirant
Reverse lookup not working ?
Hi. My model is AX1800 (not sure why it isn't in the list). I do not succed to use the local internal resolver on my Netgear (DHCP activated). The local names that I've set up in the admin interfa...
Cooper152
Make sure that your reverse DNS record matches the host name of your server. Make sure that a regular DNS lookup for the domain you have designated as the reverse DNS record entry returns the IP address in question. For example: If 70.32. 86.172 has a reverse DNS record of example.com.
Szabo52
- Make sure that your reverse DNS record matches the host name of your server.
- Make sure that a regular DNS lookup for the domain you have designated as the reverse DNS record entry returns the IP address in question. For example: If 70.32. 86.172 has a reverse DNS record of example.com.
