i_ZiGGY
Feb 11, 2025Aspirant
Revert r7800 from dd-wrt firmware back to factory firmware
I have been attempting for two to revert my r7800 router from the dd-wrt firmware back to the original factory firmware. I have downloaded the oldest firmware available, R7800-V1.0.0.28.img (I know i...
i_ZiGGY
Feb 12, 2025Aspirant
Okay, well, tell me: Is the R7800-V1.0.0.28.img the initial firmware for this router? Every other router I look at states the initial firmware, but the R7800 does not.
i_ZiGGY
Feb 20, 2025Aspirant
All the videos I've seen state that you need the initial firmware to remove dd-wrt from your router. That's the only reason.
- FURRYe38Feb 20, 2025Guru - Experienced User
You can find all FW version here: https://www.netgear.com/support/product/r7800/#download
