z1r
Dec 30, 2018Aspirant
RN212 ReadyNAS
Need help from the PROs before I blow $250-$500.00 I currently have a R7000P — Nighthawk AC2300 on a Win 10 Network wired and wireless device abpout 6 including a 5 Y/O POS WD my book mirro configu...
- Dec 31, 2018
Any of the popular NAS brands/models can be operated on any Nether or whatever other router make/model.
schumaku
Dec 31, 2018Guru - Experienced User
michaelkenward
As schumaku hints, NAS is an ethernet device that will work with any other ethernet device. Just plug it into your network and hope that your PC plays ball.
I have several brands of stuff attached to my Netgear router (ReadyNAS is too expensive for me.) But Netgear router plus Netgear NAS may well give you some added extras.
As your question is really about the RN212 you could also confirm this advice over in the appropriate bit of this forum:
- z1rDec 31, 2018Aspirant
michaelkenward, As I replied to @schumaku , I may have overthought this a bit much. Have had a MyClod Mirror for about 4 years ..less than thrilled with it in both perfomance/lreliability and overall usage . Having recently installed a R7000P unfamilar with its conneectivity capabilties conpared with my old router -- Kinda like to stick with a single brand for better chance at comaptabilty and features . I have done enough research to find a few folks who have hing a NAS off a R7000P to feeel confident in moving forward. Thanks for your reply.
- z1rJan 01, 2019Aspirant
Thanks your reply and sevaral others have given me another piece of the pizzzle to reach my decsison. :smileyhappy:
- myerswJan 01, 2019Master
Have owned a WD NAS and Synology NAS for a number of years now. They have been flawless through, Netgear, Asus, Linksys and Ubiquiti (gateway in their naming) routers without issue. As the others have said, it is just a device sitting on the Ethernet network and should be a non issue.
