mstrobbe
Jul 06, 2016Aspirant
Roku 2 won't connect to Nighthawk AC1900 R7000
Recently purchased a Roku 2 and while trying to setup it locates wireless network but is unable to connect saying "Can't connect to your wireless network." I have checked the wireless password and it is entered correct and also went to the Roku settings and set it to disable ping as I have seen many suggestions to do that, still nothing works. Looking for any suggestions before I take the Roku back?
- After spending several hours talking to Roku and Netgear with no solution, I tried switching my HDMI cables and it worked. Not sure what the issue is but it's fixed. For me the HDMI cables from Walmart did not work only cables that I got from the cable company that said on them "High Speed HDMI" worked.
- ElaineMNETGEAR Employee Retired
- mstrobbeAspirantAfter spending several hours talking to Roku and Netgear with no solution, I tried switching my HDMI cables and it worked. Not sure what the issue is but it's fixed. For me the HDMI cables from Walmart did not work only cables that I got from the cable company that said on them "High Speed HDMI" worked.
