dnance's avatar
dnance
Roku devices not connecting to the internet
I just purchased a R7000P nighthawk that got good reviews on Amazon. My Roku devices (Roku 2 amd Roku Express) will connect fine to the wireless however none of my Roku devices will connect to the in...
  • rakeshser's avatar
    Dec 21, 2017
    Try Changing the channle Settings to channal 11 . Check the router firmware update of your router. Adjust Your router Dns Settings Or Ask Your Internet Service Providor. For any other help refer to Fix Roku Internet Problem . See if this helps you fix the problem with your roku.
