dnance
Dec 16, 2017Aspirant
Roku devices not connecting to the internet
I just purchased a R7000P nighthawk that got good reviews on Amazon. My Roku devices (Roku 2 amd Roku Express) will connect fine to the wireless however none of my Roku devices will connect to the in...
- Dec 21, 2017
Try Changing the channle Settings to channal 11 . Check the router firmware update of your router. Adjust Your router Dns Settings Or Ask Your Internet Service Providor. For any other help refer to Fix Roku Internet Problem . See if this helps you fix the problem with your roku.
rakeshser
Dec 21, 2017Initiate
dnance
Dec 21, 2017Aspirant
Channel 11 was the fix! (go figure)
Thanks!
