wrch55555
Jan 25, 2021Tutor
Router - What setup is best for distance
Im looking for recommendations on best router and extender combo (without overpaying)? I am looking to add a router to my camper at campsite and looking for broadcast the network as far as possi...
Jan 25, 2021Guru - Experienced User
I'm needing more details.
What type of connection are you going to have at the camper?
Is it something from the campsite? Like connecting to the campsites wifi?
And how much range are you talking about covering?
wrch55555
Jan 25, 2021Tutor
Thanks for the quick reply...
I will have an ethernet connection and power in my camper from the campground site but it will be just mine through comcast (not entire campsite wifi).
As far as range - the more the better. Its a large campsite so the further i can get range while taking walks the better
Please let me know if more answers are needed
- plemansJan 25, 2021Guru - Experienced User
If its a standard comcast modem setup, then any router would work. Again, thats contigent if its your standard setup. If its just the campsite give you an ethernet connection while they control the router setup, then you might need an access point (most routers have an access point mode). Tough to tell of the limited info.
but distance will be an issue for several reason.
1. is because most campers have a metal exterior. this tends to make them giant faraday cages and block wifi. Not condusive to wifi.
2. Distance is an issue. broadcast power is set by the fcc and routers have maxed it out for a while. so you're not going to get a whole lot of different range out of different routers. the reason point to point systems can reach a lot further is that they're directional. They broadcast all their power at a point.
3. An option? A basic dual band router in the camper because its not going to be hard to cover full range in the camper. Then use an outdoor access point for exterior to the camper. mount it exterior to the camper (maybe slightly raised like the tv antenna's on campters) and run a wire inside the camper to connect to the router. This would give you coverage inside the camper and some range external to the camper.
- wrch55555Jan 25, 2021Tutor
Thank You
#3 seems to be the setup im looking for...
Any product suggestions - Router?Outdoor Extender? Dont want to overbuy on specs
tough to tell you off the limited info.
Everyone has different expectations on budget.
the only hardwired outdoor extender/access point I know of that netgear makes it the WAX610Y and the WBC502 is outdoor rated and has an access point mode as well.
router is more based on what you expect in terms of budget/performance. You don't need a massive router because its all contained in a camper. I'd go through netgears routers and pick what you think would work for your budget/performance goals.
https://www.netgear.com/home/wifi/routers
