wrch55555
Jan 25, 2021Tutor
Router - What setup is best for distance
Im looking for recommendations on best router and extender combo (without overpaying)? I am looking to add a router to my camper at campsite and looking for broadcast the network as far as possi...
Jan 25, 2021Guru - Experienced User
tough to tell you off the limited info.
Everyone has different expectations on budget.
the only hardwired outdoor extender/access point I know of that netgear makes it the WAX610Y and the WBC502 is outdoor rated and has an access point mode as well.
router is more based on what you expect in terms of budget/performance. You don't need a massive router because its all contained in a camper. I'd go through netgears routers and pick what you think would work for your budget/performance goals.
https://www.netgear.com/home/wifi/routers
wrch55555
Jan 25, 2021Tutor
Thanks again for the exchange here..
The point to point WBC502 will not work as i would need power at a receiver unit and i only have access to power at my campsite.
The WAX610 is promising but reviews shows it only gets 50ft range as an access point. The TP-Link EAP110 reflects 10x this distance.
Agree - I think just a basic WIFI 6 router for inside the camper - then a non point to point extender outside on a pole.. but would like more than 50ft
- plemansJan 25, 2021Guru - Experienced User
wrch55555 wrote:Thanks again for the exchange here..
The point to point WBC502 will not work as i would need power at a receiver unit and i only have access to power at my campsite.----the WBC502 has an access point mode where it acts as an access point and not as a point to point device.
The WAX610 is promising but reviews shows it only gets 50ft range as an access point. The TP-Link EAP110 reflects 10x this distance.----not sure what review you're looking at because this is a fairly newly released device. But if the tp-link is cheaper, go that route. Its only N300. might be worth looking for a dual band option link the unifi UAP-AC-m-US or the engenius ENS620ext
- wrch55555Jan 26, 2021Tutor
Greatly Appreciate the reply here..
I reached out to engenius and although they no longer sell there antennas - they did recommended a third party that does sell the SA2216 2.4GH and gets about a mile range. Paired with a few it will cover this range in all directions from a central point.
Thanks again - this was very helpful advise
