kb24's avatar
kb24
Follower
May 15, 2021
Router Already Registered
I bought this router about 6 months ago from Best Buy--brand new. We've had on and off problems with it from the get-go. Wifi drops almost every day, sometime several times a day. I have 3 kids that ...
  • antinode's avatar
    May 16, 2021
          https://community.netgear.com/t5/x/x/td-p/1845791
       What is your "this router"?  Look for "Model" on the product label.
    Firmware version?
    > Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
       Not a router.
    > Do I take it back to Best Buy?
       Your decision.
    > Is it worth it to try to reset it, like I've seen some people suggest
    > in other comments?
       Probably, but, with my weak psychic powers, I can't see what "some
    people suggest in other comments".  I can think of one way to find out.
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual (at least).  Read.
    Look for "Reset".
