dbwalton
Oct 06, 2017Aspirant
Router blocking one domain
This is the oddest thing I've ever encountered. My Nighthawk X4 AC2350 blocks beckwithmansion.com (which I own). I've eleminated it being a website, hosting, ISP or computer problem. It all points...
- Nov 08, 2017
It went away as mysteriously as it happened.
I have a theory... My theory is it had nothing to do with the router, and everything to do with my ISP and HTTP'ing to my webhost.
antinode
Oct 06, 2017Guru
> My Nighthawk X4 AC2350 blocks beckwithmansion.com [...]
What kind of "blocks" is this? What's an actual error message (from,
I assume, some Web browser or other)?
> I've eleminated it being [...]
And I can reach the site from here.
> rebooted my PC
Which is running some version or other of Windows?
> turned off all ACLs on the router
What, exactly, does that mean? ADVANCED > Security > ???
> updated the router firm ware
To which version?
> changed DNS to Google's 8.8.8.8 and 8.8.4.4
Changed _whose_ DNS, how?
I see this domain as a GoDaddy server, currently at 198.71.248.67.
Can you get the error page from that server if you specify its address
instead of the desired domain?
If the router is hopelessly confused, then it may be time to try the
usual panacea, a full ("factory") reset (and reconfiguration).
dbwalton
It is timing out. Whether I use Chrome, Modzilla or I.E., they all timeout trying to reach beckwithmansion.com
Yup. I've tried it from other locations.
> >rebooted my PC
Windows 7 Premium
Access Control Lists - yes, advanced security.
>To which version?
V1.0.0.110
The router's DNS entries under Internet Setup.
If I http://198.71.248.67 it times out too.
If I have to, I will. Wouldn't you think a power-cycle of the router would do the trick? (Which it has not.)
