FSB75
Apr 13, 2022Aspirant
Router bottlenecking (throttling) NOT WIFI
I recently upgraded to Gigabit service and did not see the expected speeds. I bypassed the router and connected directly to the modem (Hitron E31N2V1)....sure enough, after rebooting both, the speed...
- Apr 13, 2022
make sure you have access control, traffic monitoring, parental controls, and qos all disabled and then reboot the device.
Those services disable ctf which is needed for that router to hit gigabit speeds through the wan interface.
If that doesn't work, factory reset it and reinstall (not from a backup). again, leave those services disabled.
Apr 13, 2022Guru - Experienced User
