Ziiar
Jan 14, 2022Follower
Router can't detect internet from my new Modem
My current setup involves an XFinity gateway router connected to a Netgear R6700AX – AX1800. This setup has no problems. I am trying to remove the XFinity gateway from the equation and replace it wit...
- Jan 15, 2022
Greetings,
See my reply in this thread. Follow steps 1, 2, 3 and let us know if it helps.
Re: Netgear Nighthawk AX12 Wifi 6 "Internet : Hors... - NETGEAR Communities
michaelkenward
Jan 15, 2022Guru - Experienced User
Ziiar wrote: I have tried a factory reset on the Netgear and run the setup from scratch but setup fails because it still can’t detect the internet. I have reconnected the XFinity gateway and now everything is fine again.
Did your juggling with devices follow the strict order in which you have to do things?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Do this after you have reset the R6700.
shadowsports
Jan 15, 2022Hero
