fanildean
May 30, 2022Follower
Router can't detect internet from my new Modem
My current setup involves an XFinity gateway router connected to a Netgear R6700AX – AX1800. This setup has no problems. I am trying to remove the XFinity gateway from the equation and replace it w...
May 30, 2022Guru - Experienced User
Something to keep in mind with the SB8200. Its got 2x ethernet ports but xfinity only supports 1 device connected to it.
so make sure that nothing is connected to it but your router.
So follow michaelkenward 's guide but make sure its only the router connected and not your computer as well.
