Tek4Seth
Dec 13, 2021Tutor
Router configuration
Hi, My network looks like this for the moment: - a router (connected to the fiber) - my Netgear router connects to the other router on the WAN port But I would like to access the whole netw...
Dec 13, 2021Guru - Experienced User
You're in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Basically you want the first router in the string managing the network. So you'd put the 2nd connected router in access point mode.
- Tek4SethDec 14, 2021Tutor
so this is not possible?
- plemansDec 15, 2021Guru - Experienced User
Whats not possible? Getting them all on the same network?
Sure it is. You just need to only have 1 router actually managing the routing part of it. So if the netgear is what you're connecting as the 2nd router, put it in access point mode.
- michaelkenwardDec 15, 2021Guru - Experienced User
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
