Tek4Seth
Dec 13, 2021Tutor
Router configuration
Hi, My network looks like this for the moment: - a router (connected to the fiber) - my Netgear router connects to the other router on the WAN port But I would like to access the whole netw...
Tek4Seth
Dec 14, 2021Tutor
so this is not possible?
Dec 15, 2021Guru - Experienced User
Whats not possible? Getting them all on the same network?
Sure it is. You just need to only have 1 router actually managing the routing part of it. So if the netgear is what you're connecting as the 2nd router, put it in access point mode.
