mrmaz25
Apr 23, 2022Aspirant
Router configure after Cox Gigablast upgrade
I just upgraded from a 300mbps plan from Cox cable to the Gigablast plan 1gbps but I cannot get the Wi-Fi to put out what is coming into the router. Using the Nighthawk app I tested my speed and I get...
mrmaz25
I did what you said with ap mode and now I have no Wi-Fi internet. What now?
Apr 23, 2022Guru - Experienced User
Wifi on the R9000?
How did you setup and configure the R9000 for AP mode? Use a dynamic or static IP address configuration on the R9000? Static is recommended.
Be sure to connect the R9000 to the host router using the yellow WAN port of the router to connect to the host routers LAN port.
Be sure your using a good quality LAN cable. CAT6 is recommended.
- mrmaz25Apr 23, 2022AspirantI logged in to router login in safari and went step by step to turn on ap mode. I am screwed now and have no internet and cannot figure out how to change it back since I can’t access it via web page. I am completely out of my element and don’t know what to do
- FURRYe38Apr 23, 2022Guru - Experienced User
Look at the host routers connected clients page to see if the R9000 got a IP address, it should be listed here, you can connect to the R9000's web page using the new IP address it got from the host router, if the R9000 is connected right.
Couple of items to review to see if they can help:
https://www.youtube.com/watch?v=mXpGKBle-0s
Not same looking interface however same principle area and section:
https://www.youtube.com/watch?v=0Y1b_hp9rQ0
If you have a neighbor, friend or family member that can help you, please ask.
