AbiTex
May 17, 2018Tutor
Router conflicting with someone elses
This router has been working fine for about 7 months. This week it would not allow access to the internet. Suddenlink cable service kept redirecting to verify my account. The account that it pulls ...
- May 18, 2018
ISP chaged the MAC address. It's working now.
antinode
May 17, 2018Guru
> Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Is that accurate?
> [...] Suddenlink cable service [...]
Is there a modem(+router?) involved?
> [...] we renamed the account- accessed it again- [...]
What, exactly, did you change on the router?
> [...] Suddenlink doen't understand it?
Someone at Suddenlink might not understand it.
> If I turn off the router- the internet connection access goes away- so
> I can't see how I'm accessing someone elses account- 10 houses down the
> street.
Are you using a wired connection to your router? That should
eliminate any chance of your using someone else's router (except by way
of a Suddenlink problem).
> [...] my internet is now working with another router.
Are your LAN IP addresses different with the other router? (And
(now) different from those of your neighbor?)
To me, it sounds as if Suddenlink has some wires crossed (literally
or figuratively). I'd re-complain, and ask for a better explanation of
how, exactly, you could "be accessing the internet through the other
persons Netgear router".
