Dent41
Oct 26, 2022Aspirant
Router connection
My router won’t connect to my 5g network
Oct 26, 2022Guru - Experienced User
1. The router doesn't connect to the network, it broadcasts the network.
2. what router do you have?
3. what device are you trying to to connect to 5ghz?
4. Details are key, its tough to help without fully knowing whats going on.
Dent41
So sorry I hv model number R8000 and yes I’m trying to connect to 5ghz. It connects to the extender I hv but not the router
- plemansOct 26, 2022Guru - Experienced User
So you have an R8000.
Still struggling to make sense of this as you say it connects to the extender but not the router.
The r8000 doesn't connect to a router?
Or what isn't connecting to the router?
Is this another router?Again, please stop being brief. Go over your full setup, what you're trying to do, and where in the process its failing. Just saying it doesn't work, doesn't tell us anything.
- Dent41Oct 26, 2022Aspirant
I have the AR 8000 router I put in a factory reset to set up the network again because it would not connect to my 5Ghz network. when I put it back to the factory reset it showed the 5G Netwerk in my Wi-Fi setting the router just would not pick it up. It picked up the 2.4 GHZ not the 5G. I have a Wi-Fi extender when I switched over to the Wi-Fi extender It was using the 5GHZ network. I’m just trying to get my router to connect to my 5Ghz and not the 2.4 GHz
My router is a R8000 model number
On the Netgear app that I have on my phone I am seeing that my router is not on the 5G Network but when I switch over to my extender which is also on the same app it is showing the extender is on the 5Ghz
