JJPEngr
Jun 15, 2017Aspirant
Router Connects wirelessly to internet, but wired connection does not
My RC6700 router has worked fine since new. My wireless connection to the internet still works normally. However, My wired ethernet connection to the router results in a message on my iMac - "Ethern...
- Jun 23, 2017
I just let NETGEAR Genie complete network mapping (it took awhile), but that solved the problem. All devices (wired and wireless) are now properly connected.
Problem solved.
netwrks
Jun 15, 2017Master
Try another Ethernet cable.. Or. maybe Norton is blocking. Try disabling Norton, and see if you can an IP address, and get to the Internet.
EDIT: Also, try another LAN port on the router..
JJPEngr
Jun 23, 2017Aspirant
Problem solved.
