DMA97701
May 12, 2022Aspirant
Router constantly becoming wedged
Nighthawk X6S R7900P Direct connection to ISP cable modem 13 different WiFi devices connected Every few days, the router becomes wedged (unresponsive) for no apparent reason. Internal logs don'...
DMA97701
Firmware Version: V1.4.3.88_1.3.50
ISP Modem Manufacturer: Arris
ISP Modem Model: TM3402A
There are numerous WiFi signals in the area, but all signal strengths pale in comparison to mine.
Every time the router becomes wedged, I power cycle both the router and the cable modem.
Thanx.
May 12, 2022Guru - Experienced User
Try a factory reset on the router.
Also enable IPv6 on the router as well...
- DMA97701May 12, 2022Aspirant
Dang. I've factory reset the thing at least a dozen times now. Thirteenth time's the charm?
IPv6 is already enabled.
Thanx again.
Nope. Thirteenth time was most definitely not the charm. Wedged again shortly after reconfiguration, following reset. Thanx.
- FURRYe38May 12, 2022Guru - Experienced User
Would be interesting to see if you disabled all wifi radios on the router to see if the router continued to lock up or not...
Also what CAT# LAN cable is in between the modem and router? CAT6 is recommended.
