Jmara
Jun 24, 2022Initiate
Router constantly blocks main device from WIFI
Looking for some insight on why my nighthawk 7000 router constantly blocks my main device I use to connect through the app to the router. Also, I notice device names keep changing and why does the rou...
Jun 24, 2022Guru - Experienced User
What router do you have? There's usually a C, R, D in front of the model number to tell us what it is. Its not just 7000.
Are you on an apple/iOS device? If so, make sure icloud relay and private mac/ip address is disabled.
- JmaraJun 24, 2022InitiateThanks for the response.
My router is R7000P and I am using iOS phone, which my IP address was toggled on private. I turn off private, so hopefully that will fix the issue.
Thank you
