Cleverfiend
May 20, 2019Tutor
Router constantly needs rebooting - no internal connectivity (just internet)
I've suffered from the flaky wifi with this router (although it's better than it used to be) but that's easy to recognise as all connectivity just stops (and the debug page often shows the router reb...
- Jun 27, 2019
Interestingly that upgrading to the Tomato firmware has removed ALL the problems I had with the router. It is now rock solid and doesn't need rebooting on a daily basis.
That proves the problem was the shoddy Netgear firmware - even will all the unwanted crud like Disney Circle turned off.
My only hesitation with using Tomato is updates/patches and bugfixes - but it has breathed new life into my router, at least until I upgrade to a new model (which will not be a netgear!)
microchip8
May 20, 2019Master
which firmware version? not "the latest" but a number
Have you done a factory reset?
