Cleverfiend
May 20, 2019Tutor
Router constantly needs rebooting - no internal connectivity (just internet)
I've suffered from the flaky wifi with this router (although it's better than it used to be) but that's easy to recognise as all connectivity just stops (and the debug page often shows the router reb...
- Jun 27, 2019
Interestingly that upgrading to the Tomato firmware has removed ALL the problems I had with the router. It is now rock solid and doesn't need rebooting on a daily basis.
That proves the problem was the shoddy Netgear firmware - even will all the unwanted crud like Disney Circle turned off.
My only hesitation with using Tomato is updates/patches and bugfixes - but it has breathed new life into my router, at least until I upgrade to a new model (which will not be a netgear!)
IrvSp
May 20, 2019Master
OK, let me guess... you are running W10 on at least ONE PC?
That is the REAL reason I think, especially when it happens with the Modem as well.
The root problem is what MS depricated (that means they do not enable it normally) which is SMB 1 and that means the COMPUTER BROWSER as well. MS did this on W10 as of the old Fall Creator version, V1709.
Long story short, you need to ENABLE SMB 1 on ALL Win10 PC's. See https://www.windowscentral.com/how-access-files-network-devices-using-smbv1-windows-10 on how to do this. MS switched to WS-Discovery for sharing, and NG has NOT implemented this, and I was told will NOT and any router! (newer routers may have this function though)
The basic problem is that NG is using NETBIOS for discovery of shares. That requires SMB 1 running. When a PC is designated as the holder of the list of devices it tries to get the list. It can't so when others look for the list nothing is found and you can't see or connect devices to each other (simplified overview). Enabling SMB1 makes this all work.
Give it a try and report back.
- CleverfiendMay 20, 2019Tutor
Firmware
Hardware Version R7000 Firmware Version V1.0.9.64_10.2.64 GUI Language Version V1.0.9.64_2.1.38.1 I've already enabled SMBv1 for my NAS drive.
The problem (when it occurs) is between any two devices - for example my ipad won't be able to see my ipcam. Reboot and all works fine. Computer can't see printer - reboot and printout comes straight out. I don't have the right combination of devices to test if this happens on the wired network but it definitely happens on the wired network (both frequencies)
- CleverfiendJun 27, 2019Tutor
- myerswJun 27, 2019Master
