Martinc13
Nov 11, 2020Follower
Router CR700
I have a TP Link router CR700 which is running my Mediacom cable.I want to replace with Nighthawk.Which model would you recommend.
DarrenM
Nov 12, 2020Sr. NETGEAR Moderator
Well, you may need to keep the CR700 and use it in modem only mode. But I suggest looking at our wifi 6 routers.
https://www.netgear.com/landings/wifi6/
DarrenM
