TomNoseLittle
May 28, 2021Follower
Router does not have 8 Digit Pin Number
Our new laptop is not asking for my router's password. It will only accept an 8 digit pin code. My R7000 router does not have an 8 digit pin code. Does anyone know of a work-around? Thanks to all. To...
antinode
May 28, 2021Guru
> Our new laptop [...]
Not a very detailed description of anything. (Or its operating
system.)
> [...] is not asking for my router's password. It will only accept an 8
> digit pin code.
For what? What, exactly, are you doing?
> [...] My R7000 router [...]
Firmware version? Connected to what?
> [...] does not have an 8 digit pin code. [...]
Says who? "[it] does not have" and "I have not found" are spelled
differently for a reason. Where did you look?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Specify WPS Settings"? Further reading might not hurt, either.
