Tamumiket
Apr 13, 2024Aspirant
Router does not support https protocol R9000 Nighthawk
Some time after I purchased the R9000 router the https protocol stopped being supported and I may only access the admin interface via http Are there any suggestions to restore https access to th...
michaelkenward
Apr 13, 2024Guru - Experienced User
That's how it works by default. Why do you want https?
If you insist, try here:
- Advanced
- Advanced setup
- Web Service Management
Be prepared for it to break things.
Tamumiket
Thank you for the prompt reply!
http is not encrypted so the login passwords are sent clear text. Someone already logged in the WiFi can intercept these packets
I cannot see the web services option. Have they stopped updating the OS for this router ?
- microchip8Apr 13, 2024MasterEnabling HTTPS on the router does not mean it's globally available to the LAN/WiFi. It's only for the router's web interface so login credentials are encrypted.
- TamumiketApr 13, 2024AspirantLogging on to the router with https as admin is what I’m looking for.
I cannot find the option in the admin web interface to enable https to connect to the router- FURRYe38Apr 13, 2024Guru - Experienced User
Try loading Voxels 3rd Party FW.
HTTPS options wasn't a user configuration on the R9000 and is not a requirement. Users have to have LAN side access to do any nefarious things. I've never had HTTPS enabled on other routers that supported it as I'm the only one with access to routers heres.
