Tamumiket
Apr 13, 2024Aspirant
Router does not support https protocol R9000 Nighthawk
Some time after I purchased the R9000 router the https protocol stopped being supported and I may only access the admin interface via http Are there any suggestions to restore https access to th...
Tamumiket
Logging on to the router with https as admin is what I’m looking for.
I cannot find the option in the admin web interface to enable https to connect to the router
Apr 14, 2024Guru - Experienced User
Try loading Voxels 3rd Party FW.
HTTPS options wasn't a user configuration on the R9000 and is not a requirement. Users have to have LAN side access to do any nefarious things. I've never had HTTPS enabled on other routers that supported it as I'm the only one with access to routers heres.
- KitsapApr 14, 2024Master
FURRYe38 wrote:Try loading Voxels 3rd Party FW.
HTTPS options wasn't a user configuration on the R9000 and is not a requirement. Users have to have LAN side access to do any nefarious things. I've never had HTTPS enabled on other routers that supported it as I'm the only one with access to routers heres.I will save you some time. I am running the latest Voxel firmware, version 1.0.4.73HF, on my R9000. HTTPS login for the user interface is not an available option.
If you have users logged in to your R9000 network that are sniffing around for admin passwords, you have bigger problems than HTTPS access.
