packerbacker12
Dec 07, 2017Initiate
Router download speeds are slow on Nighthawk R8000
I just recently switched to Spectrum here in WI. My download speed when connectly directly to the Spectrum provided modem is 108MB. When connect any of my devices to the route,r either wireless or ha...
- Dec 08, 2017
Things that people have tried to fix the "router is throttling my modem" issue with various devices:
- Ensure that the cable from the router to the modem is up to the job
- Check that you have the latest firmware (and "factory reset" the device)
- Check that you have the right internet settings for your ISP (especially MTU)
- Turn off QoS
- Turn off the Traffic Meter
Netgear also advises that you should turn off QoS if you are on Gigabit Internet. You don't need it.
azwebbie
Dec 07, 2017Aspirant
I am having a similar issue with my Nighthawk R8300 X8 Router. Running Win 10 Home 64bit with Cox Gigablast Internet service. Wired Download speed is around 900 Mbps but my best wireless speed on the 5G with Smart Connect is 150Mbps standing right next to the router. I also have a Nighthawk X4S Wifi Mesh Range Extender installed and it does pretty much maintain that 150 Mbps throught the house (Wireless speeds are measured with the Netgear Wifi Analysis app on an Android Tablet) but my wireless speeds should be 10 to 15 times faster than what I am getting. I have Factory Reset the router and re-installed the current Firmware Version V1.0.2.106 from the Netgear Support site.
What additional information do you need and what suggestions do you have to increase my wireless speeds?
- michaelkenwardDec 08, 2017Guru - Experienced User
- Turn off QoS
- azwebbieDec 08, 2017Aspirant
Thanks for the response Michael. I have already addressed each of your suggestions and nothing has helped. The Router is Netgear R8300 and my wired speed is close to the gigabit expected but wireless speed even right next to the router max is 150 Mbps.
Any other suggestions? Thanks
azwebbie wrote:
...but wireless speed even right next to the router max is 150 Mbps.
Wireless speeds will never match wired speeds. The chances of getting wifi to run at anything near gigabit are pretty well zero.
Wifi speeds depend on the technology used in the source (the router) but equally on what the clients can handle.
By the way, you seem to have hijacked a question about wired speeds with your own query about wifi speeds. My answer was really intended for packerbacker12 who asked the first question.
What you call a "similar issue" is no such thing. You don't even have the same hardware as packerbacker12.Nor are your Internet speeds comparable.
If you want the Netgear support team to respond to your query, perhaps you should start your own discussion.
- packerbacker12Dec 08, 2017Initiate
Thank you very much for the advice and it has seemed to solve the problem. I'm now getting around 90MB plus on my wired and wireless connections to the router.
