Philbomb
Apr 30, 2018Aspirant
Router Dropping Internet Connection
My router drops it's signal multiple times daily. I downloaded an update about two weeks ago. Prior to the update. this was not happening. What do I do to regain a consistant signal?
- Jun 13, 2018
Hi Philbomb,
Have you tried changing the channel on the router?
You may want to try to play around with the channels to see which channel is best to use.
Here's a reference of how to change wireless channel:
Blanca
Community Team
JamesGL
May 03, 2018NETGEAR Employee Retired
Hi Philbomb,
Does it happen on both wired and wireless devices?
Have you reset the router to factory default?
Philbomb
May 04, 2018Aspirant
It happens on wireless connections. Yes, I reset the router to factory specs.
- Blanca_OJun 13, 2018NETGEAR Employee Retired
Hi Philbomb,
Blanca
Community Team
- Blanca_OJun 17, 2018NETGEAR Employee Retired
Hi Philbomb,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
