CobbT
Sep 03, 2018Guide
Router Dropping Internet Connection
I’ve Had Nighthawk AC 1900 Smart WiFi Router 11 months w/o issues. Recently started dropping the internet signal. I now reboot about every 20 minutes. When working signal strength is off the charts. ...
- Sep 05, 2018This router shuts down about every 10 minutes, then reboots itself. Yesterday I was told my firmware needs updating. I checked NetGear App & it says my firmware is the most recent version (V1.09.34).
If it turns out being a firmware issue, how do I update it?
CobbT
Sep 05, 2018Guide
shadowsports
Sep 05, 2018Hero
Greetings,
Chronic reboots. While this is often indicative of a bad or corrupt FW flash, a failing or faulty power supply can also cause chronic or unexplainable restarts. In addition to manually flashing the FW (not using an App or the auto update check and update) in the GUI, resetting the router and setting up from scratch is also often a good practice.
I suggest you start with these steps. Its perfectly fine to reflash the same version of FW. But, your issue might not be resolved simply by reflasing and resetting if other hardware issues exist.
- CobbTSep 06, 2018GuideUnfortunately my internet signal is so choppy I can’t complete the actions you recommended.
I purchased this unit 9/17/2017. Is this router under any kind of mfg warranty?- michaelkenwardSep 06, 2018Guru - Experienced User
CobbT wrote:
Unfortunately my internet signal is so choppy ....What does that mean?
It loses the link to the modem? The wifi dies? What do all the LEDs look like when this happens?
It might also help if you told people what the modem is in front of this router. The model number could be useful.
As shadowsports suggested, a factory reset might be useful.
See the Factory Settings bit in the manual.
So far your messages have been terse, with too little information for anyone to diagnose what it going on.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reason.
- CobbTSep 06, 2018GuideWhat are the steps to : 1) fix a ‘bad or corrupt FW flash, and/or a failing or faulty power supply; and
manually flashing the FW (not using an App or the auto update check and update)?
I already reset the router and resetted up from scratch., w/no change.- michaelkenwardSep 06, 2018Guru - Experienced User
CobbT wrote:
What are the steps to : 1) fix a ‘bad or corrupt FW flashCare to answer my earlier questions? The answers to those will affect the answers to that one.
In particular:
"What do all the LEDs look like when this happens?"
Without detailed knownedge of what is goin bg on at your end, we are all in the dark.
As to the power supply, try one with the same output and see if that helps. Netgear uses industry standard power supplies. Just find one with right volts and (+/-) polarity and enough amps.
