1Amador's avatar
1Amador
Follower
Oct 09, 2021
router firewall settings on my Nighthawk AC 1750 model number R6700 ?
How can I find out what my firewall settings are on my router. I have a Nighthawk AC 1750 model number R6700. I can't find it in the Nighthawk app.
  • michaelkenward's avatar
    Oct 10, 2021
    They don't exist.
    If you have a particular setting that you need to change, check the manual.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
    I have no idea which app you are using, but those apps are less capable that using the browser graphical user interface (GUI). Check the manual for how to use that.
