softerist's avatar
softerist
Apprentice
Jan 15, 2020
Router Firmware Version V1.0.5.8
After last update, firmware notes tell that now it supports the v1.18.3 Plex Server.   But as you can see in the attachment, this is not happening. Done restart few times, enable/disable update, a...
  • DarrenM's avatar
    Jan 17, 2020
    Have you tried to downgrade the firmware and see if ready share started to work again?
