Bag
Jul 10, 2017Aspirant
Router Frequency?
I have had ongoing connectivity issues. My ISP has finally advised that it could be frequency interference and asked me to adjust my frequencies. I do not believe this is my issue since when I conn...
- Jul 10, 2017
Bag wrote:I have had ongoing connectivity issues. My ISP has finally advised that it could be frequency interference and asked me to adjust my frequencies. I do not believe this is my issue since when I connect to the router via ethernet cable the connectivity issues remain. Is there a way to adjust the frequencies on this router?
Thank you,
The frequency of the wifi channels would impact the wireless functions but not the wired lan connections you can find very fast if the router or the connection from the modem is the problem. You can bypass the router by connecting a computer direct to the modem and see if the problem stays or goes away. You can the change the channels of the wifi bands to the lease used channels thats were a wifi scanning problem would help out . The need program may be on one of your wireless devices if you have any.
William10a
Jul 10, 2017Master
Thank you,
