Djacobsen80123
Dec 21, 2021Aspirant
Router goes offline when using Excel
This is a weird problem but my nighthawk goes offline every time I use Microsoft excel, I mean every time! Ive stopped using excel at work just because it creates problems for the bar/restaurant if ...
Dec 21, 2021Guru - Experienced User
Have you tried excel on a different pc/laptop? Just to see if its a pc issue or the actual router.
Djacobsen80123
Actually I have, I only use my iPad and my iPhone at work, but this issue happens whether I enter data on my phone or my iPad, we only use apple stuff here so I can't speak to if it happens with windows.
- plemansDec 21, 2021Guru - Experienced User
do wired and wireless devices drop? Or just wireless?
what router is it?
What firmare is on it?
What modem/gateway is it connected to?
Do the logs show any issues when you're using excel?
- Djacobsen80123Dec 21, 2021Aspirant
thx for the help,
both wired and wireless go offline, anything attched to it stops working
nighthawk r7000
v1.0.11.126
I use comcast for my internet services so it's connected to their modem
I am not sure what logs you are talking about but I have never seen an error message in notification.
what actual modem is it from comcast?
Has a factory reset on the r7000 been performed lately?
The firmware on it changed significantly and it responds favorably to factory reset/reinstalls
