Rgnmgr
Jun 16, 2021Aspirant
Router has no coax connector. Need to connect Spectrum internet to my R8000P X6S
How to connect acoax cable to router that has no cable connector.
Rgnmgr
Jun 17, 2021Aspirant
My current older Netgear C3700 has a coax cable internet connector on it.
My new Netgear R8000P only has an ethernet internet port, nothing for a coax cable (spectrum internet).
antinode
Jun 21, 2021Guru
You don't; you connect it to a cable modem.
> it.
C3700[v1] or C3700v2? Look for "Model" on the product label.
If the modem section of your C3700[vX] satisfies your modem
requirements, then you should be able to disable its router, and use it
as your modem.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Cable Your Modem Router to a Router or Gateway".
You might want to check with your ISP to see if they support that
modem(+router) at the Internet speed you've subscribed to.
