TheTrigger
May 30, 2022Aspirant
Router home page colors
I have an R7000 and when after logging in and the web page loads I am unable to read the information because of the colors. The literally blend in with the background. Kind of funny and exasperating....
- May 31, 2022
Your browsers have a dark theme or dark mode enabled? I have this enabled on MS Edge and see this same thing. Disable it fully and the web page returns to normal. edge://flags/#enable-force-dark
Look at the routers web page in FireFox or Opera.
Kitsap
May 30, 2022Master
Another thing you should mention is what web browser are you using?
Do you have any themes installed in the web browser?
TheTrigger
May 31, 2022Aspirant
This is happening with Edge and Chrome. I was using light theme. Switched to dark theme but looks exactly the same.
- TheTriggerMay 31, 2022Aspirant
I didn't get both web browsers or both themes in my screenshots but you can see what I'm seeing and it doesn't change based on browser or light vs dark theme.
- FURRYe38May 31, 2022Guru - Experienced User
OK, thank you . Using a different browser seems like the best answer for me.
- FURRYe38Jun 01, 2022Guru - Experienced User
