TheTrigger
May 30, 2022Aspirant
Router home page colors
I have an R7000 and when after logging in and the web page loads I am unable to read the information because of the colors. The literally blend in with the background. Kind of funny and exasperating....
- May 31, 2022
Your browsers have a dark theme or dark mode enabled? I have this enabled on MS Edge and see this same thing. Disable it fully and the web page returns to normal. edge://flags/#enable-force-dark
Look at the routers web page in FireFox or Opera.
May 30, 2022Guru - Experienced User
There a screen capture of what you're seeing?
What FW version do you have loaded?
Mine looks fine in MS Edge in Windows 10:
TheTrigger wrote:
I have an R7000 and when after logging in and the web page loads I am unable to read the information because of the colors. The literally blend in with the background. Kind of funny and exasperating. How can I change the router web page colors?? Thank you for your time and patience.
TheTrigger
May 31, 2022Aspirant
I've got it set to automatically update but it looks like I need to manually update. I'll do that, check the results, then get back with screenshots.
