TheTrigger
May 30, 2022Aspirant
Router home page colors
I have an R7000 and when after logging in and the web page loads I am unable to read the information because of the colors. The literally blend in with the background. Kind of funny and exasperating....
- May 31, 2022
Your browsers have a dark theme or dark mode enabled? I have this enabled on MS Edge and see this same thing. Disable it fully and the web page returns to normal. edge://flags/#enable-force-dark
Look at the routers web page in FireFox or Opera.
May 30, 2022Guru - Experienced User
There a screen capture of what you're seeing?
What FW version do you have loaded?
Mine looks fine in MS Edge in Windows 10:
TheTrigger wrote:
I have an R7000 and when after logging in and the web page loads I am unable to read the information because of the colors. The literally blend in with the background. Kind of funny and exasperating. How can I change the router web page colors?? Thank you for your time and patience.
TheTrigger
May 31, 2022Aspirant
Need to post second screenshot because the system here won't let me have two pics in the same reply even though I just did it. 🙂
