TroyK
May 26, 2022Aspirant
Router internal IP is not the same as my external IP provided by provider.
I have 2 R7000 routers. On one of them the router internal ip (found while using the browser to access the router) is the same as my say... (what's my ip) ip address. On the other router those two ...
- May 26, 2022
They might be at different locations, but the one you have a screensnip of is in a double nat.
May 26, 2022Guru - Experienced User
Do you have both of these routers connected to each other? If so this would be a double NAT condition:
https://kb.netgear.com/30186/What-is-Double-NAT
TroyK
No, they are not connected to each other.
They are at different physical addresses.
V1.0.11.134_10.2.119
- TroyKMay 26, 2022Aspirant
I think tonight I'll turn off the router, turn off the modem.
Wait 5 minutes.
Boot the modem, wait till it's fully up.
Then turn on the router and see if the numbers match...
I'm betting that they will....
Fingers crossed....
thanx
