TroyK
May 26, 2022Aspirant
Router internal IP is not the same as my external IP provided by provider.
I have 2 R7000 routers. On one of them the router internal ip (found while using the browser to access the router) is the same as my say... (what's my ip) ip address. On the other router those two ...
- May 26, 2022
They might be at different locations, but the one you have a screensnip of is in a double nat.
May 26, 2022Guru - Experienced User
A couple things.
1. like FURRYe38 says, you're running a double nat. According to your screenshot, your internal ip address is the 10.0.0.* address while the wan port is a192.168.1.***. meaning you're showing us the info from the 2nd router. That'd be the double nat. Put your 2nd router in AP mode so you're all on the same subnet/internal ip address range.
2. There's a difference from internal lan addresses to public ip addresses. google is your friend for more info on this
3. What are you trying to achieve? Telling us you're having ip address issues doesn't tell us what you're trying to resolve or do with this info. That might help for us to understand what you're base issue is you're trying to fix.
- TroyKMay 26, 2022Aspirant
Thank you!, great forum help! really...
I called optimum and they put their router in 'bridge' mode.
Restarted the modem and router and bang... numbers match...
No wonder I couldn't get port forwarding to work at home!!!
Again, to both you folks...
Thank you for taking the time to provide such pertinent feedback.
Issue solved....
Cheers
Troy
- FURRYe38May 26, 2022Guru - Experienced User
Would be nice to know what the brand and model is of that modem router. 😉
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- TroyKMay 26, 2022Aspirant
Sorry - Netgear, Nighthawk R7000
