TroyK's avatar
TroyK
Router internal IP is not the same as my external IP provided by provider.
I have 2 R7000 routers. On one of them the router internal ip (found while using the browser to access the router) is the same as my say... (what's my ip) ip address. On the other router those two ...
  • plemans's avatar
    May 26, 2022
    They might be at different locations, but the one you have a screensnip of is in a double nat.
