Cgot
May 25, 2022Aspirant
router is interfering with my work laptop Cisco voip softphone. delay to the point of not working
Router is interfering with my laptop Cisco voip softphone, delay to the point of not working. My phone works in my office with no issues. I have tried to hard connect at home as I do at work and...
May 25, 2022Guru - Experienced User
Not much to go on.
What NG router do you have?
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
Try option #2 first...
Cgot
Very helpful NETGEAR Nighthawk X4S R7800 and Xfinity gateway modem router combo. We connected hard wire to first Xfinity combo and the phone works now bypassing out Netgear router. Xfinity gateway arris model TG1682G I think
- Charles258May 26, 2022Aspirant
check this out : https://www.nextiva.com/blog/voip-troubleshooting.html/My Fortiva
