Friedbones
Feb 04, 2017Guide
Router issues
I am trying to get a phone number for support for my new router. But all I see are PAID support....why is that when I just purchased this new Dec 31st and received it on Jan 6th 2017? Should there ...
- Feb 05, 2017
Finally managed to setup and change all passwords on the router with regard to the WiFi as well. I need to remember never to try this kind of stuff when I am tired. First thing this morning I was able to, not only accesss the router without all the hullabalu I experienced last night, but reset after firmwear update, and changed all the passwords.
I was confusing the router with the online account login info...no wonder I was unable to get anything to work last night. Once I understood what I did wrong last night, I was able to get everything fixed up and all the necessary PWs adjusted. So all is good now.
I want to thank everyone who responded and helped me with this last night and this morning. I appreciate all the help.
Friedbones
Feb 04, 2017Guide
Manual...yea...I thought it was forgotten when I opened the box. Now i just have to find it.
Router model: AC1750 Smart WiFi Router R6400
Just got a new firmwear update tonight...did not see a number for it....where do I find that?
Friedbones
Feb 04, 2017Guide
Could not find the manual....all I saw was an inforamtion page with an option to purchse. I was hoping to find a download of the manual, but it did not really show up on the support page ...maybe wrong page? Not sure, but did not see anything that was familiar.
- FriedbonesFeb 04, 2017Guide
ahah...never mind. I finaly found it...but it was not obvious. Seems odd that when I log in then go to support for anything I am offered another "login" box? Can't stay in my account for that? Anyway, I did find it....but the two questions I want answers to are not really noted.
1. How to change the "Admin" login name to something else, and
2. How to make our router private instead of public.
- LeeHFeb 04, 2017Prodigy
I forgot something importanat. Before you do anything else update your firmware to the latest one. Several security fixes came out in the latest firmware.
Then after the update. Reset your router by pressing in the reset button on the back of the router for about 10 seconds until the power light turns orange and begins to blink.
Then change the password back to the one you changed it to previously.
Already did this
Then after the update. Reset your router by pressing in the reset button on the back of the router for about 10 seconds until the power light turns orange and begins to blink. Why do I have to reset ?? I already rebooted...
Then change the password back to the one you changed it to previously. Why do I need to go backwards?
The user name admin can not be changed. But it is a great thing you already changed the password.
The support page for your router is: https://www.netgear.com/support/product/R6400.aspx
The manual can be found at: http://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_07Aug2015.pdf
The SSID (Wireless Network Name) can be hidden but I would not do that until I got everything else setup.
You should reserve all your IP addresses after you get everything, including cell phones, hooked up to your new routers network.
Thank you very much for this input. So, why can't we change the "admin" login name? That makes no sense....it gives anyone 1/2 of a 2pc puzzle...not very secure.
Reserving all our IP addresses? We only have our pcs hooked up ...I don't have anything else and my son uses Verizon phone so he does not use our internet. We both are cable connected to the router rather than WiFi...since we both play online games, there is less lag that way, as long as Comcast network cooperates.
But how do I make our router private?
To hide the SSID open up the web browser to the routers admin page. Then under the Basic tab select Wireless. On the Wireless Setup page uncheck the Enable SSID Broadcast boxes. Click Apply at the top of the page.
I guess with only two devices it would not be helpful to reserve IP addresses. But if your son wants to connect his cell phone up to the network I would reserve IP addresses because cell phones leave the house and when they return they sometimes receive a new IP address that is the same as one of your computers and neither the computer or the phone will be able to use the network if that happens. And it has happened to me.
