AlanRittel
Sep 13, 2017Follower
Router issues
We are using a Netgear Nighthawk AC1900 Smart WiFi Router, Model # R6900. We live in a 2,600 sq foot house that has 3 levels. The router is on the middle level. Apple TV works fine on the ...
- Sep 25, 2017
Hi AlanRittel,
It could be that the signal strength is low on the bottom area. You can check the following extenders.
http://www.netgear.com/home/products/networking/wifi-range-extenders/
JamesGL
Sep 25, 2017NETGEAR Employee Retired
Hi AlanRittel,
- William10aSep 27, 2017Master
You could also use another as a access point a set of power lan adaptor could connect the two routers if a lan cable is not possible.
- JamesGLSep 27, 2017NETGEAR Employee Retired
Hi AlanRittel,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
