One9Delta's avatar
One9Delta
router issues
So I recently just upgraded my internet speed to gigblast and bought a new modem to handle the speed CM1200 and after installing the modem now my router the nighthawk Ac1900 sends out a signal but al...
  • antinode's avatar
    antinode
    Dec 26, 2019
    > Model is R7000 [...]
       Firmware version?  The current consensus seems to be that
    V1.0.9.42_10.2.44 is a better bet than anything newer.  To load
    different firmware:
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  (For older versions, under Firmware and Software
    Downloads, look for "View Previous Versions".)  Find the kit(s).
    Download the kit(s) you want.  Read the "Release Notes" file for
    instructions.
    > [...] ( assuming I know how to reset).
       Visit http://netgear.com/support , put in your router model number,
    and look for Documentation.  Get the User Manual.  Read.  Look for
    "reset".  (Repeat for the modem?)
