Saimon
Aug 02, 2021Aspirant
Router issues
Hi, I am having issues my router.If I restart/reboot my router,the router lost the memory and I have to re setup the router from beginning. Also i am not getting full signal and sometimes keep dis...
Aug 02, 2021Guru - Experienced User
1. you have the r8000?
2. what firmware is on it?
3. what modem/gateway is it connected to?
4. "not getting full strength". describe this more in details. what speeds are you getting? over 2.4ghz? or the 5ghz?
- SaimonAug 02, 2021AspirantI m using NBN ( FTP)
2.4ghz getting 45-60 mbps
My internet speed 200mbps but not getting that speed
Firm ware v1.0.4.74
Model no :R8000- plemansAug 03, 2021Guru - Experienced User
Saimon wrote:
I m using NBN ( FTP)----that just tells me your in australia and you have fiber to the premises
2.4ghz getting 45-60 mbps----thats actually a good speed over 2.4ghz. 2.4ghz is a slower network and sensitive to interference. There's a lot of misunderstanding about realistic speeds over wifi. You can read here for more details. : Understand Wi-Fi 4/5/6/6E (802.11 n/ac/ax) (duckware.com)
My internet speed 200mbps but not getting that speed---what wired and 5ghz speeds are you getting?
Firm ware v1.0.4.74
Model no :R8000- SaimonAug 03, 2021AspirantI am using wifi..didn’t try with wire though.
Also not getting full signal wifi network inside my house.Is there any way I can boost my signal or any advice please
