Retired_Member
Apr 03, 2023Router keeps dropping connection
I am at my wits end with this. I have BOTH, an Orbi AX4200 system, as well as a Nighthawk R7000P. I had some many ongoing issues with the Orbi dropping connection (both wired and wifi) that I gav...
Retired_Member
Apr 03, 2023welp i just spent 20 mins replying to your message only for it to immediately delete it. Got a nice response badge for my time though apparently.
Apr 03, 2023Guru - Experienced User
Try and copy the text into note pad or word pad then copy and paste as Plain Text in the post box.
Possible you have too much your posting.
Or use the Quotes (") you see in the post tool bar to reply to my post, then you can full in text after each question or suggestion then try to post it back.
- Retired_MemberApr 03, 2023
Ok will do. Leaving work in a few minutes so I'll just wait till im home so i can give you more info and actively troubleshoot
- FURRYe38Apr 03, 2023Guru - Experienced User
đ
