Retired_Member
Apr 03, 2023Router keeps dropping connection
I am at my wits end with this. I have BOTH, an Orbi AX4200 system, as well as a Nighthawk R7000P. I had some many ongoing issues with the Orbi dropping connection (both wired and wifi) that I gav...
Apr 04, 2023Guru - Experienced User
Ok, just checkin.
Something else that you might try, take the router to say a friend, neighbor or families place and run same thing there to see if problem follows or not. Might help narrow down if it's the router or something else.
Retired_Member
Apr 04, 2023hmm good thought. I might give that a try. Currently going back and forth with my ISP regarding the Modem to trouble shoot it as well just in case.
- FURRYe38Apr 04, 2023Guru - Experienced User
I believe those PACE modems are getting up in age as well.
Something to try, configure the modem back to router mode, use the modems DMZ for the IP address that the NH router gets and test again. Can also test your downloads thru the modem in router mode with your PC to see if same thing happens or not, with out the NH router connected. - Retired_MemberApr 04, 2023
Im not sure what youre referring to with 'PACE' modems. This is a Sagemcom Fast 3896, which is the newest modem currently offered by them.
Opps, sorry about that. Mis-read the model. Sorry about that.
No worries! Just confused me is all lol
Not enough coffee. đ
